Equipment for ball joint repair: prerequisites for use, subtleties of operation and popular models
Equipment for ball joint repair is very popular today. Why? I propose to sort this out together.
The quality of roads, unfortunately, is far from always meeting the standards that we would like to see. This is well known not only to all drivers, but also to passengers. The first thing that suffers from this is the ball joints, which during the movement of the vehicle experience destructive effects from all sides. In the picture, the zones of maximum load exerted on the nodal connection are marked in red:
Equipment for ball joint repair: picture of ball joint Sectional picture of a ball joint
The node itself consists of two elements:
  • Sleeve;
  • Swivel ball.
Between them is a special polymer, which:
  1. It softens the force of ball impact on the sleeve;
  2. Minimizes the effect of friction of metal parts against each other.
All problems, including wrest the wheel on its side, are possible if the polymer liner is worn, which is inevitable over time.
1-76-300x217.jpg Wrest the wheel-turned wheel example
SJR technology avoids such a catastrophic outcome and, with timely intervention, maintains the performance of the ball joint almost endlessly. How it works? Let’s figure it out.
SJR Technology
There are two methods for ball support recovery using SJR equipment:
1.Indiscriminately
Equipment for ball joint repair: removal of old polymer Removal of old polymer
  1. Drill a hole in the case of the sleeve;
  2. Burn the remains of the old polymer with a gas burner;
  3. In the extruder, melt a new batch of polymer
  4. Under high pressure, the molten polymer is injected into the cavity between the ball and the sleeve through a hole previously made.
  5. The solution fills all the voids, solidifies and forms a new liner, not inferior in its characteristics to the factory insert.
2. Demountable
The collapsible method is more complicated and longer, but also more efficient. It is used when there is significant wear on the ball joint, the appearance of rust on the ball.
In this case, the repair begins with the following steps:
  1. Cut the sleeve in half.
  2. Polish the ball.
  3. Brew sleeve.
The final steps are the same as in the previous method.
Benefits
The advantages of using this technology are quite obvious. It:
  • Economic benefit. Recovery is always cheaper than buying a new part;
  • Universality. Suitable for the restoration of any ball joints and steering tips;
  • The compact dimensions of the necessary equipment. Even the largest machine can easily be rearranged from one place to another by one person and can be comfortably located not only in a spacious car service, but also in a small garage workshop;
  • Cheap consumables.
Variants of suitable equipment
The operations described above can be carried out using various equipment that differs from each other:
  • At the cost of;
  • In size;
  • Power;
  • In level of automation.
We will briefly consider four models presented on our website.
The simplest version of equipment for recovery of ball joints and steering includes:
  • An extruder for heating and forming a polymer consistency;
  • Three interchangeable adapter fittings, with which the solution is charged under pressure into the problem area;
  • Remote thermometer that allows you to monitor the temperature of the detail at a distance;
  • Five polymer rods, shipping container and instructions.
The pressure of such a device is only 25 kg / cm2 , and it needs a compressor with a capacity of 7-10 atm at the service station. The set is quite economical in terms of financial expenses, as it costs only 180 $, and is compact, but quite demanding on additional equipment and labor costs from the operator.
This model is reinforced:
  • A more powerful piston capable of creating pressure up to 80 kg / cm 2 ;
  • The control unit simplifies the operation of the device.
But it also costs a little more: 370 $.
In the next modification, the piston power reaches 100 kg / cm2 . But its main advantage is the presence of a high-quality mechanism for centering the ball joint. Such an addition allows during the introduction of the molten polymer to firmly and reliably fix the part in one position. This facilitates the work of the operator, and the quality of the result improves.
The cost of such equipment reaches 640 $.
The SJR 3 machine will cost 1 180 $ for your workshop, but will eventually work out every cent invested and will bring considerable profit from above. This is a fully automated unit, equipped with all technological advances.
Here are just a few of its most significant advantages:
  • The created pressure – 240 kg / cm 2 ;
  • Full control of the melting process;
  • Automatic nozzle feed;
  • Mechanical clamp and centering of the ball joint;
  • Robust cast housing.
The restoration of ball joints and steering tips using SJR technology is a technologically advanced, profitable and easily feasible process in the presence of the necessary equipment. It is noteworthy that such equipment is available in different price categories, so that every car repair shop can make the optimal choice for itself.
      link hidden, please login to view, a division of link hidden, please login to view, announced it is adding new general repair parts commonly used by transmission repair shops in over 50 locations. With the addition, these general repair parts will now be available at the majority of Transtar’s 70 locations, simplifying complex vehicle repair by enabling repair shops to find the parts they need in one location, the company said. The aftermarket brands with which Transtar is partnering as part of the expansion, and their respective repair parts, include:
      • Denso – ignition coils, oxygen sensors, spark plugs
      • ProMax – Brake pads, rotors, chassis, control arms
      • Sunsong® – Brake hoses
      • GSP® – CV axles, hub assemblies
      • DFC – Brake pads, rotors, calipers
      “The addition of general repair parts at a significant number of our locations is an exciting enhancement and one that is a part of Transtar’s overall commitment to becoming a one-stop solution for our customers,” said Tom DeMille, executive vice president, sales and marketing. “We’re committed to supporting shops in all types of repairs. Whether that’s a general automotive repair or more complex transmission repair, Transtar has the parts needed to keep the world moving.”
      For a complete listing of Transtar locations and products, visit
      Congressman Neal Dunn (Fla-02) introduced the Right to Equitable and Professional Auto Industry Repair Act or the “REPAIR Act,” a bill that would ensure vehicle owners have access to important repair and diagnostic data needed for auto repairs, on February 25, 2025. Currently, automakers are restricting vehicle owners and automotive repair shops from accessing repair data and tools, resulting in higher repair costs, fewer service options and longer wait times for vehicle maintenance.
      link hidden, please login to view would affirm that this data belongs to the vehicle’s owner, not the manufacturer. “American consumers deserve full control over their vehicle repair and maintenance data to ensure they can find the best service for their vehicle at a reasonable price. Unfortunately, vehicle manufacturers are standing in the way of American consumers accessing their own data to use the repair shop of their choosing, limiting consumer choice,” said Congressman Dunn. “For far too long, manufacturers have championed anti-competitive practices by withholding crucial maintenance information, squeezing their customers and independent repair shops.
      “Your vehicle belongs to you, not the manufacturer. I am introducing the REPAIR Act to provide a binding, workable solution to anti-competitive behavior in the auto repair industry to reaffirm consumer control over their vehicle maintenance data and empower them to work with repair shops big and small.”
      “Americans are tired of lip service about lowering prices or respecting the trades. We want to be able to fix our own stuff and to be stewards of our stuff and not reliant on a stream of cheap disposable crap. But auto manufacturers have made it increasingly difficult to have real agency,” said Rep. Marie Gluesenkamp Perez. “It’s time for Congress to listen to ordinary Americans and pass right to repair legislation.”
      “We sincerely thank Dr. Dunn for his leadership in tackling this existential threat to consumers and standing up for the rights of vehicle owners and vital businesses,” said Bill Hanvey, president and CEO of the Auto Care Association. “The REPAIR Act gained significant support and momentum in the previous Congress, demonstrating the broad, bipartisan recognition of the need to protect consumers’ right to repair their vehicles. Lawmakers, industry leaders, and everyday drivers understand that fair access to vehicle repair data is essential for competition, affordability, and consumer choice. With its reintroduction, we have an even greater opportunity to get this critical legislation across the finish line.”
      “Americans want a car repair market that guarantees choice and protects accessible, affordable, and safe vehicle repairs,” said Justin Rzepka, executive director of the CAR Coalition. “We commend Rep. Neal Dunn and Rep. Marie Gluesenkamp Perez for their leadership in upholding consumer rights and promoting a free and fair car repair market. Today’s reintroduction of the Right to Equitable and Professional Auto Industry Repair (REPAIR) Act marks an important step forward in limiting unfair repair restrictions and empowering consumers to fix their vehicles on their own terms.”
      “NFIB is excited to work with and support Rep. Dunn on this important legislation. The REPAIR Act is a much-needed piece of bipartisan legislation to increase competition in the automotive repair industry,” said Andrea McGee, principal of federal government relations at NFIB. “Almost 90 percent of NFIB members support right to repair, making it one of NFIB’s top 10 priorities. NFIB thanks Rep. Dunn for his tireless work on this issue that impacts so many small businesses across all industries.”
      “MEMA Aftermarket Suppliers thanks Congressman Dunn for reintroducing the REPAIR Act. This bill is a critical step toward protecting consumer choice, competition and innovation in the automotive aftermarket. Ensuring fair access in a cybersecure way to critical repair and maintenance data allows aftermarket manufacturers to continue innovating and providing high-quality, affordable parts to consumers. Without this access, competition is stifled, costs will rise, and consumer choice will be diminished. MEMA Aftermarket Suppliers strongly supports this legislation to protect a vibrant and competitive aftermarket that benefits drivers, repairers, and manufacturers alike,” said Paul McCarthy, president of MEMA Aftermarket Suppliers.
      “PAMA’s member companies and independent automotive maintenance shops around the country play a vital role, ensuring that consumers have access to timely and cost-effective repair options for their automobiles,” said Justin Cialella, former PAMA president and chair of the Government Affairs Committee. “We commend and applaud Congressman Dunn for his leadership on the REPAIR Act, a critical milestone in our industry’s effort to protect consumers rights, preserve a fair marketplace with regard to vehicle telematics, and combat deceptive marketing practices.”
