announced it is now offering Advantage automated series clutch and Cummins flywheel kits for the Eaton-Cummins Endurant automated manual transmission (AMT). The two will be sold in the same kit for the first time, according to Eaton.
An
news release announcing the product launch explained that a flywheel, which is the interface between the engine and clutch, is bolted to the engine and spins when in operation. The clutch cover, which is bolted to the flywheel, also spins, and the driven disc of the clutch engages against the flywheel, which over time can cause wear.
“Today’s manufacturers recommend that flywheels should be replaced, rather than the previous practice of resurfacing worn flywheels,” said Leandro Girardi, director, aftermarket, Eaton’s Mobility Group. “This ensures the flywheel fits correctly to engage with the clutch, and prevents fault codes, excessive wear and vibrations.”
Eaton said its Advantage Automated clutch is the original equipment clutch used in the Endurant transmission.
      Certain statements herein are “forward-looking statements” within the meaning of the Private Securities Litigation Reform Act of 1995. Forward-looking statements are usually identifiable by words such as “anticipate,” “believe,” “could,” “estimate,” “expect,” “forecast, “guidance,” “intend,” “likely,” “may,” “plan,” “position,” “possible,” “potential,” “probable,” “project,” “should,” “strategy,” “target,” “will,” or similar language. All statements other than statements of historical fact are forward-looking statements, including, but not limited to, statements about the Company’s strategic initiatives, restructuring and asset optimization plans, store and location opening plans, operational plans and objectives, and statements regarding expectations for future business and financial performance, as well as statements regarding underlying assumptions related thereto. Forward-looking statements reflect the Company’s views based on historical results, current information and assumptions related to future developments. Except as may be required by law, the Company undertakes no obligation to update any forward-looking statements made herein. Forward-looking statements are subject to a number of risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements. They include, among others, the Company’s ability to hire, train and retain qualified employees, the timing and implementation of strategic initiatives, risks associated with the Company’s restructuring and asset optimization plans, deterioration of general macroeconomic conditions, geopolitical factors including increased tariffs and trade restrictions, the highly competitive nature of the industry, demand for the Company’s products and services, risks relating to the impairment of assets, including intangible assets such as goodwill, access to financing on favorable terms, complexities in the Company’s inventory and supply chain and challenges with transforming and growing its business. Please refer to “Item 1A. Risk Factors” of the company’s most recent Annual Report on Form 10-K filed with the Securities and Exchange Commission (“SEC”), as updated by the company’s subsequent filings with the SEC, for a description of these and other risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements.
      APA announced Axon US as the newest addition to TruStar. Founded in 2008, Axon US began with a small office in Midtown Manhattan and a basement workspace in Long Island City. Its founder, Siyao Ji, started Axon independently, building the company from the ground up. He established the company with a clear vision: to create a streamlined supply chain system that efficiently meets the needs of the auto industry.
      Axon initially operated solely as an online retailer but expanded its presence to better serve customers through offline channels. In 2021, the company moved into a 20,000 sq. ft. warehouse in Queens to accommodate its growing inventory and improve order fulfillment. Today, Axon US serves both online and offline customers through its warehouse showroom, with plans to open a dedicated brick-and-mortar store that is aiming to open in Q4.
      link hidden, please login to viewsaid Natasha Huang has been with Axon US for about six months as a buyer. Previously a salesperson for an Asian auto parts wholesale distributor, she joined Axon to deepen her understanding of the auto supply chain and continue growing in the industry. “Axon US is eager to expand its presence in the automotive industry by joining TruStar, fostering connections with other members and strengthening relationships with key brands,” said Huang.
      “We are excited to welcome Axon US to the TruStar family and look forward to the collaboration and innovation they will bring to our network,” said Steve Tucker, President of APA.
