The vehicle received a full service including an oil and filter change. The system was leak checked and the engine 43ehad good oil pressure. Two days later, the customer calls reporting a loss of oil pressure symptom. Mechanic A says…a defective oil filter is the cause of the loss of oil pressure. Mechanic B says…a […]
      Selling the Upgrade
      Bottom Line for Counter Pros
      A Dynamic Kickoff
