Create an account
Register a new account
Sign in
Sign In Now
      ZF Aftermarket and HDA Truck Pride announced a partnership to distribute WABCO products to the CV independent aftermarket. The announcement comes as both companies exhibit at Heavy Duty Aftermarket Week (HDAW) 2025 in Grapevine, Texas.
      According to ZF, the partnership expands access to the full line of WABCO products for commercial vehicles – including air compressors, air dryers, trailer anti-lock braking systems (ABS), wheel-end solutions and more – to the independent aftermarket through HDA Truck Pride’s extensive distributor network. WABCO’s broad portfolio of innovative solutions improve the safety, efficiency and intelligence of commercial vehicles, at all stages of the vehicle lifecycle, the company said.
      “We are excited to partner with HDA Truck Pride, a premier marketing group, to make WABCO products more readily available in the independent aftermarket,” said Steve Bashir, commercial vehicle business leader,
      link hidden, please login to view. “With ZF Aftermarket brands TRW and SACHS already available through the HDA Truck Pride Network, we are strengthening our commitment to offer a full range of genuine OE products, remanufactured solutions and quality aftermarket parts to support distributors, fleets and vehicle owners across North America.” “
      link hidden, please login to view is dedicated to delivering unmatched value and service to our customers,” said Tina Hubbard, president and CEO of HDA Truck Pride. “Partnering with ZF Aftermarket to make WABCO products available to our distribution network strengthens our value proposition and optimizes our customers’ market presence to drive success.” The post
    • By TachMaker
      Bosch Mobility Aftermarket announced the re-launch of its passenger car and light duty truck battery offering, now known as the Bosch Premium Battery Program. The company said this revitalized program embraces a new name emphasizing its exclusive focus on premium batteries and includes new stock-keeping units (SKUs) for the Bosch S5 Premium Power Flooded Batteries and the Bosch S6 High Performance AGM Batteries.
      “This emphasized focus on premium batteries, with 90% market coverage, guarantees shop owners and end-users alike will confront less complexity in our battery line, while enjoying greater inventory efficiency,” said Dennis Krob, senior product manager at
      link hidden, please login to view. “We’ve been listening to customers and understand these two areas are critically important in today’s market. We’re proud to be refreshing our offerings at a premium level to meet these demands, while helping drive business and streamline operations.”
      link hidden, please login to view said it will expand its portfolio of S5 Premium Power Flooded Batteries by 13 new SKUs. These batteries boast a three-year warranty and provide dependable starting power, a long service life and reduced risk of acid leakage in newer car models with high electronic demand. The new program also includes three new SKUs for the Bosch S6 High Performance AGM Batteries. According to the company, these batteries promise a lifespan up to two times longer than conventional alternatives and provide consistent, optimal power for start-stop vehicles and models that use regenerative braking. The S6 batteries offer a warranty guaranteeing free replacement for four years after the date of purchase.
