The differences and options between OEM brake pads and aftermarket brake pads
1. Price
2.Quality
3.Adaptability
4.Variety and Customization
5. Performance issues
6.Convenience
7.Warranty Issues
Aftermarket brake pad:
Link to comment
Share on other sites
    • By Mossi9283
      This question arises when searching for replacement injectors for a VW Polo 6R. It's possible that the same part may have different OEM references depending on the manufacturer, and 03L 130 277 S could be one of the alternative part numbers for the injector in question. Always verify part compatibility by cross-referencing OEM numbers to ensure a proper fit.
      I found on this site:
      link hidden, please login to view has launched the new BKS1002 fuel pump kit. This new model is engineered specifically for high-pressure, in-tank applications and is the highest flowing fuel pump in the TI Automotive catalog, according to the company. The BKS1002 fuel pump kit will feature:
      High-pressure, high-flow E5LM brushless screw pump 3’ long wire harness for tank mounting High-performance inlet filter Support of 1,000+ horsepower “The BKS1002 further expands our line of fuel pump kits with another high-pressure, high-performance technology, but adds additional flexibility for enthusiasts,” said Brian Altenberger, aftermarket business director, TI Automotive. “There has been a significant demand in the market for the option to purchase a standalone pump and the BKS1002 now provides that option.”
      TI Automotive Aftermarket said its BKS1002 must be driven with a sensorless 6-step commutation method or other suitable methods such as Sinusoidal or Field Oriented Control (FOC). The BKS1002 pump, filter and wire harness are all components from the BKS1001, but without the controller. The BKS1001 will remain available, however customers who already utilize a controller may now opt to purchase a kit without one, offering additional build flexibility.
    • By roybrakepad
    • By roybrakepad
      Quality Certifications
