How is Semi-metallic brake pads ?
Semi-metallic formulations have a higher content of friction material fibers (reaching 45-50%), providing excellent heat dissipation performance. Compared to ceramic and low-metallic formulas, they can better handle high temperatures. Below 500°C, ceramic formula products wear less than semi-metallic. Above 500°C, the performance and wear of semi-metallic formula products are the best, but the likelihood of noise and brake squeal increases. Ketulla has addressed these issues by redeveloping semi-metallic brake pads to avoid the possibility of squealing at high temperatures. Reliable Semi-metallic brake pad supplier:
Link to comment
Share on other sites
    • By roybrakepad
    • By roybrakepad
      Quality Certifications
    • By roybrakepad
      1. Price
      2.Quality
      3.Adaptability
      4.Variety and Customization
      5. Performance issues
      6.Convenience
      7.Warranty Issues
    • By Mia
      1) Look through your eyes
      2) Listen through your ears
      4) Judge by professionals
      1) Improve driving habits
      2) Wash regularly
