How to choose Ceramic Brake Pads ?
Ceramic Brake Pads: Ceramic brake pads are made from ceramic fibers and non-ferrous filler materials. They offer excellent braking performance, low dust generation, and reduced noise levels compared to organic and semi-metallic brake pads. Ceramic brake pads are often favored for their longevity and consistent performance.
Semi-Metallic Brake Pads: Semi-metallic brake pads contain 30%~50% metal fibers, typically steel, along with other materials such as organic compounds and resins. These brake pads offer enhanced durability and heat dissipation, making them suitable for high-performance applications. However, they may produce more brake dust and noise compared to ceramic brake pads.
Link to comment
Share on other sites
    • By roybrakepad
    • By roybrakepad
      Quality Certifications
    • By roybrakepad
      1. Price
      2.Quality
      3.Adaptability
      4.Variety and Customization
      5. Performance issues
      6.Convenience
      7.Warranty Issues
    • By Mia
      1) Look through your eyes
      2) Listen through your ears
      4) Judge by professionals
      1) Improve driving habits
      2) Wash regularly
