What are aftermarket brake pads?
Aftermarket brake pads are simply parts that are not made by the original car manufacturer. They are replacement parts that are manufactured by third-party companies, and most are designed and constructed to fit exactly the same and work as well or better than the OEM brake pads they replace.
In fact, the term “aftermarket” can be a bit confusing. In reality, the more accurate term, and the one we use, is “alternative part”. That’s because these non-OEM brake pads are just that – an alternative to using OEM brake pads for repairs on your vehicle.
Link to comment
Share on other sites
    • By roybrakepad
    • By roybrakepad
      Quality Certifications
    • By roybrakepad
      1. Price
      2.Quality
      3.Adaptability
      4.Variety and Customization
      5. Performance issues
      6.Convenience
      7.Warranty Issues
    • By Mia
      1) Look through your eyes
      2) Listen through your ears
      4) Judge by professionals
      1) Improve driving habits
      2) Wash regularly
