Ceramic or semi-metallic brake pads what types of brake pads are best for trucks?
Typically, our customers demand the following from brake pads:
  • Braking performance.
  • Good pedal feel.
  • No noise (no long, sharp noise or other annoying noises), little to no dust.
  • No vibration during braking.
  • Long-lasting durability.
To meet these demands, KETULLA, as a professional brake pad factory, invests in research and development to formulate friction material compounds suitable for market needs, Types of brake pads:
  • link hidden, please login to view
The reason for adding ceramic fibers to the friction material mixture is that ceramic fibers are stable and significantly enhance the performance of the friction material. On the other hand, adding metal fibers to the friction material is for heat dissipation, especially when used in brake pads that can generate high temperatures.
The ceramic formulation provides a smoother pedal feel, whether the pads are at normal or high temperatures because the friction coefficient of ceramic brake pads decreases slower than that of semi-metallic. Additionally, ceramic formulations produce minimal noise and vibration, resulting in quieter braking with less damage to the brake discs. Ceramic pads hardly produce any dust, keeping the wheels clean and extending their lifespan. The craftsmanship of ceramic pads is superior, visibly appearing grayish-white, and nearly no dust is visible on the wheels.
Furthermore, the dust generated during braking with ceramic formula products is minimal, keeping the wheels clean and prolonging their lifespan. Despite having many advantages compared to other formulations, the ceramic formula is still not suitable for heavy-duty vehicles such as trucks used for towing or hauling, where semi-metallic pads would be more appropriate.
Semi-metallic formulations have a higher content of friction material fibers (reaching 45-50%), providing excellent heat dissipation performance. Compared to ceramic and low-metallic formulas, they can better handle high temperatures. Below 500°C, ceramic formula products wear less than semi-metallic. Above 500°C, the performance and wear of semi-metallic formula products are the best, but the likelihood of noise and brake squeal increases. Ketulla has addressed these issues by redeveloping semi-metallic brake pads to avoid the possibility of squealing at high temperatures. This is achieved by incorporating advanced materials such as graphene into the mixture and using a balanced ratio, which has been widely accepted by more purchasers.
The disadvantages and advantages of ceramic and semi-metallic brake pads
Advantages of KETULLA Ceramic Brake Pads:
  • Minimal thermal fade: During continuous braking, even when brake temperatures instantly rise above 500 degrees Celsius, they do not melt and still maintain excellent braking performance.
  • High braking force, resulting in shorter braking distances.
  • Low probability of noise generation.
  • Excellent braking performance in wet conditions and on slippery roads, without squealing.
  • Prolongs the lifespan of brake discs: Ceramic brake pads, as they do not contain metal fibers, do not cause scratches on brake discs, making them more friendly to brake discs.
Disadvantages:
  • Higher price: Ceramic brake pads are priced 30% higher than semi-metallic brake pads.
  • Soft braking feel: This is not necessarily a disadvantage, but rather a characteristic of ceramic brake pads.
Link to comment
Share on other sites
    • By roybrakepad
    • By roybrakepad
      Quality Certifications
    • By roybrakepad
      1. Price
      2.Quality
      3.Adaptability
      4.Variety and Customization
      5. Performance issues
      6.Convenience
      7.Warranty Issues
    • By Mia
      1) Look through your eyes
      2) Listen through your ears
      4) Judge by professionals
      1) Improve driving habits
      2) Wash regularly
