2013 / 2019 BN BM MAZDA 3 2.0 PETROL ENGINE / MOTOR
Cash For Caravans Brisbane
By CarPartAU,
- buy second hand engines
- buy/sell car parts online
- (and 2 more)
- 7,643 views
Car Part | 2006 CHRYSLER PT CRUISE CARPET
By CarPartAU,
- genuine brand auto parts
- buy a car engine
- 1,246 views
By CarPartAU,
- buy a car engine
- buy and sell car parts online
- (and 5 more)
- 1,232 views
buy second hand engines Holden Special Vehicles VF HSV LSA CONVERSION KIT COMPLETE
By CarPartAU,
- car engine online
- buy a car engine
- (and 3 more)
- 1,303 views
Standard Motor Products, Inc. (SMP) announced it continues to add to its line of kits. Standard and Blue Streak offer Kits and Multipacks in a variety of categories. Among its most popular are Blue Streak GDI High-Pressure Fuel Pump Kits and Ignition Coil Multipacks, the company said. Blue Streak GDI High-Pressure Fuel Pump Kits help technicians solve low-fuel-pressure symptoms by replacing all components at once to ensure a complete repair,
link hidden, please login to view said. These kits include an all-new high-pressure fuel pump, cam follower, the required seals, and mounting hardware. Ignition coils can lose spark energy over time, causing poor fuel mileage and reduced performance and if one coil fails, it is likely the others are on track to fail. Blue Streak Ignition Coil Multipacks include a full, matched set of new, better-performing coils, saving time, restoring performance and reducing comebacks. SMP said other popular kits include complete Standard Turbocharger Kits, Oil Filter Housing Kits, and Fuel Injector Multipacks and Blue Streak Blower Motor Resistor Kits, Camshaft and Crankshaft Sensor Kits, Variable Valve Timing (VVT) Service Kits and VVT Solenoid Kits. In the past two years, specific Blue Streak Kits have been awarded the Best New Product of the Year and Best Problem-Solver by the Import Vehicle Community, a community of the Auto Care Association.
New coverage has recently been introduced across many of these categories, according to SMP. Blue Streak GDI High-Pressure Fuel Pump Kits have been released for 3.7 million General Motor vehicles, like the 2019-16 Chevrolet Cruze, 2019-18 Chevrolet Equinox, and 2019-18 GMC Terrain. Standard Oil Filter Housing Kits are new for multiple popular makes and models, including the 2024-19 Jeep Grand Cherokee, 2024-19 RAM 1500, 2024-19 Dodge Durango, 2016-11 Volvo S60, and more. Blue Streak Cam and Crank Sensor Kits have been released for a variety of popular Ford vehicles, and Standard Turbocharger Kits are new for Ford, Volvo, and General Motors vehicles like the 2019-16 Chevrolet Cruze and Buick Encore, SMP said.
Commenting on the expansion, John Herc, vice president of vehicle control marketing at
link hidden, please login to view, said, “Parts professionals are looking for more complete kits and multipacks for a number of reasons. First, it helps technicians perform a complete repair without having to chase parts from multiple places. Additionally, service writers find it easier to explain one line item on an invoice rather than a list of parts. Whatever their reason, they look to Standard and Blue Streak for complete repair solutions.” The post
link hidden, please login to view announced its new USMW professional series link hidden, please login to view are now available. The new fuel pump modules provide application coverage for several Toyota, BMW, RAM and Nissan vehicles.
Visit
link hidden, please login to view for detailed applications, or contact customer service for further information.
By ctplg
