Check Engine Light On? Could Be A Faulty O2 Sensor
Bosch Mobility Aftermarket announced the re-launch of its passenger car and light duty truck battery offering, now known as the Bosch Premium Battery Program. The company said this revitalized program embraces a new name emphasizing its exclusive focus on premium batteries and includes new stock-keeping units (SKUs) for the Bosch S5 Premium Power Flooded Batteries and the Bosch S6 High Performance AGM Batteries.
“This emphasized focus on premium batteries, with 90% market coverage, guarantees shop owners and end-users alike will confront less complexity in our battery line, while enjoying greater inventory efficiency,” said Dennis Krob, senior product manager at
link hidden, please login to view. “We’ve been listening to customers and understand these two areas are critically important in today’s market. We’re proud to be refreshing our offerings at a premium level to meet these demands, while helping drive business and streamline operations.”
link hidden, please login to view said it will expand its portfolio of S5 Premium Power Flooded Batteries by 13 new SKUs. These batteries boast a three-year warranty and provide dependable starting power, a long service life and reduced risk of acid leakage in newer car models with high electronic demand. The new program also includes three new SKUs for the Bosch S6 High Performance AGM Batteries. According to the company, these batteries promise a lifespan up to two times longer than conventional alternatives and provide consistent, optimal power for start-stop vehicles and models that use regenerative braking. The S6 batteries offer a warranty guaranteeing free replacement for four years after the date of purchase.
Dorman Products, Inc. announced it has named Tayfun Uner president of its light-duty business segment.
In this newly created role, Uner will be responsible for driving strategic growth and overseeing all commercial and operational aspects of Dorman’s largest business segment, the company said.
“We are pleased to welcome Tayfun to Dorman,” said Kevin Olsen,
link hidden, please login to view president and chief executive officer. “His broad experience and proven ability to drive growth, enhance financial performance and foster a positive culture will be key to driving the continued success of our Light Duty business. This new role completes our segment transition, with a formalized leadership structure for each of our three business segments.” Uner joins Dorman with an extensive global background in consumer goods, most recently serving as SVP of three Newell Brand business units, according to Dorman. Prior to that, he held strategic positions around the world with increasing responsibility at McKinsey & Company, Procter & Gamble and Carlsberg Breweries. He holds an undergraduate degree from Bogazici University (Istanbul, Turkey) and a Master of Business Administration degree from Harvard University.
“I feel privileged to join the innovative team at Dorman. I am excited to build on the strong foundation of our brand and trusted solutions like our Dorman OE FIX products and working closely with our channel partners to accelerate the growth of the automotive aftermarket by helping solve people’s repair problems,” Uner said.
By ctplg
