Holden Equinox For Wecking
- 322 views
- 1,285 views
- 1,172 views
- 2,502 views
2010 MAZDA CX9 ENGINE / MOTOR FOR SALE WITH WARRANTY & OTHER PARTS
By CarPartAU,
- used car parts
- car part finder
- (and 1 more)
- 1,195 views
By chevyguy
I've got a 2014 Chevy Equinox with new pluigs, coils, fuel injectors, recent top-engine carbon clean, new AC Delco O2 sensors, and relitively new CAT. Getting a P219A-00 for Fuel trim cyliner balance. Any ideas where to start diagnosing? I saw this online as possible causes:
Leaking or contaminated fuel injectors Low fuel pressure or running out of fuel Leaking evaporative emission (EVAP) canister purge valve Exhaust or intake air system leaks Exhaust gas recirculation (EGR) system Positive crankcase ventilation (PCV) system is leaking or the valve is stuck open Ignition system Incorrectly seated engine oil dipstick, tube or oil fill cap Just curious if anyone has had this issue with a GMC of Chevy and succesfully diagnosed.
By Harley M
Hey there, I am curious if anyone knows where to locate the “plug” to INSTALL a block heater in my 2013 Chevy Equinox LT 2.4L.
I have not been able to find anything online about where a block heater can be installed and if it even has a plug to slide through. Am I better off getting a magnetic block heater?
Thanks in advance.
By chevyguy
All of a sudden my ABS and traction control lights came on, on my 2014 chevy equinox. C0110-00 and C0110-61. I did an oil change and tranny flush, two minutes later issues. Hooked up the scanner, can't seem to engage the ABS pump.
C0110-61 is Pump motor circuit - Stuck
C0110-00 is Pump motor circuit
I'm thiking the ABS pump or module failed all of a sudden?
By chevyguy
Have some issues going on with my 2014 Chevy Equinox 2.4. Check engine light was flashing and went into sort of limp mode and then back to normal. Check engine light is off but scanner shows history codes PO171, PO300, PO2097. Looks like misfire, fuel trim lean, post cat fuel trim high limit.
Right now it’s running smooth but every once in a while on the highway it seems sluggish and RPMs will drop.
I replaced the spark plugs and cleaned the throttle body but happened again. I just replaced the oxygen sensor after the cat with a spare I had, so we’ll see. I’m almost thinking a fuel injector issue or intermittent timing. No other codes.
The O2 sensor I just took out is charred a bit:
Ideas?
By chevyguy
I'm working on a 2011 Chevy Equinox 2.4 that has a PO442 code, for an evap leak. Sometimes its the fuel cap. However, I decided to buy a
link hidden, please login to view and see if I can determine where the leak is coming from. I purchased from Amazon
link hidden, please login to view Lines all look good to and from the vapor canister. I shot it back up to the fuel cap to see if its bad and noticed smoke from the wheel well. I took the wheel well cover off and it looks like smoke is coming from the filler neck, where it's rusted pretty bad.
