Understanding The Science of Shocks
✔️ Poor Fuel Efficiency
✔️ Starting Problems
✅ Final Thoughts
What Are OEM Control Modules?
A major change is underway for the bottles of engine oils that line the shelves of American auto shops and supply factory and service fill stations.
ILSAC GF-7—the next specification for passenger car engine oils—will see its first license on March 31, 2025. That means all factory and service fill engine oils must deliver new levels of performance across a range of criteria, most particularly fuel economy.
For auto service professionals, it’s worth staying educated on developments like these to best satisfy the wants and needs of your customers. In this article, we’ll explore the new performance requirements of GF-7 in more detail, as well as the science that goes into delivering next-generation performance.
A Focus on Fuel Economy: GF-7 Performance Requirements
The new GF-7 specification requires that next-generation lubricants contribute to enhanced fuel consumption rates, as well as enhanced fuel economy retention over the course of the oil drain. To the average driver, these fuel economy gains will likely go unnoticed. But taken across all cars on the road, they will have a major impact on emissions reduction for the American auto population.
But those aren’t the only new requirements. GF-7 will require lubricants to deliver heightened levels of overall engine protection and will measure the lubricant’s ability to prevent low-speed pre-ignition (LSPI), piston deposit control, and premature timing chain wear over extended periods. These are important attributes. For example, LSPI is a potentially catastrophic problem unique to modern gasoline direct injection (GDI) and turbocharged GDI (TGDI) engines.
The specification calls for advanced performance in several other areas, including deposit control, seal compatibility, wear and corrosion protection, oil pumpability, and catalyst compatibility. Taken comprehensively, the requirements of GF-7 will help to better protect cars on the road while enabling new-model engines to meet their full potential.
Elsewhere, it’s important to note that GF-7 will in fact be split into two separate categories: GF-7A, which covers legacy viscosity grades 0W-20, 5W-20, 0W-30, 5W-30, and 10W-30, and GF-7B, which covers 0W-16, a lower viscosity that some OEMs have specified in new-model vehicles to drive even higher fuel economy benefits than the GF-7A category. For auto service professionals, it’s worth knowing how and when to recommend GF-7B products to customers in conjunction with automaker recommendations.
The Science Behind Performance
To understand the technology that goes into GF-7 performance or other OEM specifications, it’s helpful to understand the anatomy of an engine oil. Formulations are composed of three primary component parts:
Base oil. The base oil is the carrier fluid and delivers basic performance. It makes up the majority of the formulation and is a critical building block for formulating a high-quality lubricant. Additive. This is the key performance enabler, allowing the finished product to meet operational requirements when in use. Viscosity modifier and pour point depressant. This component ensures the final product will deliver consistent flow across a broad range of operational temperatures and climates. These components complement each other to create optimized performance that will need new performance specifications. Generally, engine oil producers will utilize high-quality base stocks blended with additives and viscosity modifiers to deliver the required performance.
There can be some complexities here. Base oil availability and pricing can be inconsistent, and access to the highest-quality options is not always a guarantee for formulators. But by taking advantage of advanced additive technology, engine oil producers can typically meet the required performance standards with a range of available base stocks.
Additionally, elevated additive performance can enable the use of viscosity modifiers (VMs) that help maximize engine durability while achieving the necessary fuel economy requirements of new specifications. Typically, passenger car engine oils are formulated with VMs that maintain a shear-stability index (SSI) of 35. The higher the SSI, the more easily the finished product will shear, contributing to fuel economy gains. Lower SSI VMs, by contrast, may hinder some of those fuel economy gains, but will deliver higher levels of durability. For example, heavy-duty engine oils for commercial trucks are typically formulated using VMs with an SSI of 25.
Higher-performance additives, however, can change those considerations. Top-tier additives enable finished engine oils to achieve higher fuel economy gains in combination with lower-shear (25 SSI) VMs. This means no compromises when it comes to protection and durability while delivering meaningful fuel economy contributions.
GF-7 is nearly here, and it raises the bar for what modern lubricants can contribute to today’s and tomorrow’s vehicles. Ultimately, today’s additive science is the reason engine oils are reaching those loftier performance standards—and that is a positive thing for every car on the road today.
Padu Sreenivas is Product Manager at The Lubrizol Corporation and manages Lubrizol’s North American passenger car motor oil business. He has over 25 years of industry experience and has held numerous positions in technology, testing and commercial roles globally.
Common Signs of ECM Failure:
One resource to explore is
The parts industry is a very diverse marketplace. While the landscape is mostly dominated by retail chains and jobber stores serving the general automotive and light truck segment, there are several other specialized parts vendors catering to imports, collision and refinish, powersports, ag and turf, and OEM vehicle brands. Each requires its own unique set of skills, including the heavy truck market.
For many of us behind the counter, our only experiences with heavy trucks are when stock orders are delivered to our stores. Heavy-duty parts specialists work in a very different setting than the “year, make, model” format of retail parts, or the VIN-driven world of a dealership parts department. On those occasions when even a veteran P2-certified parts specialist is presented with a request for heavy-duty parts, we are required to think a little differently and be prepared to dig a little deeper to find solutions.
Trucks are classified by their gross vehicle weight rating (GVWR), with light trucks like Tacoma, Silverado 1500, F-250, and Ram 3500 representing classes 1-3, up to 14,000 pounds. Medium duty (14,001 to 26,000 pounds) covers class 4, 5, and 6, including models like the Ram 4500, F550, and Kodiak 6500. These medium-duty trucks all feature hydraulic brake systems, and are sometimes catalogued alongside their light-duty counterparts. Heavy-duty vehicles, on the other hand, are catalogued primarily by the major components used to build the vehicle.
Heavy duty generally describes class 7 and 8 trucks, with a GVWR over 26,000 pounds. Some class 7 trucks feature hydraulic or air-over-hydraulic brake systems, but the majority of trucks in these two classes rely on air brakes to stop these heavily loaded vehicles. Air brakes operate much like hydraulic brakes, using air pressure instead of hydraulic fluid to apply brake force when the pedal is depressed. Air pressure is created by an on-board compressor, and distributed through a series of valves and tubing to the foundation brakes (disc or drum brake components). Semi-trailers, when coupled to the tractor’s air supply, operate the same way. In case of a drop in air pressure, spring-loaded parking brakes serve as an automatic emergency brake.
Cataloguing foundation brake parts often requires a combination of measurements, identification of manufacturer-specific design elements, and even axle model numbers. Air components require the understanding and identification of thread pitch and sizing, cross-referencing numbers from multiple vendor information sources, and a solid understanding of what each type of valve does within the system.
Engine, drivetrain and suspension components are similarly dependent on how an individual truck was spec’d from the factory. A cement mixer or tri-axle dump truck requires a considerably heavier suspension design than an over-the-road tractor regularly hauling van body trailers full of potato chips. Even within the same model range, a truck manufacturer might offer engines from Cummins, Caterpillar or Detroit, each one mated to one of several manual or automatic transmission options from Eaton, Fuller or Allison. Throw in Rockwell, Eaton or Dana axle packages in one of a dozen different gear ratios, and the combinations become nearly unmanageable.
In our automotive cataloguing, those drivetrain options (and most other parts requests) would generally be found through a simple year/make/model search, but with HD parts, that’s only the beginning. At the dealership level, VIN entry yields a copy of the build sheet or bill of materials (BOM) with the relevant options identified, and OE part numbers called out in the electronic catalog. For aftermarket professionals, its off to various manufacturer catalogs, searching individual component or assembly model numbers and/or serial numbers to collect part information. With more focus on identification of standalone parts that are not necessarily exclusive to one vehicle manufacturer, it simply requires a different approach than what many parts specialists are used to.
There are instances when traditional aftermarket catalog skills come into play, and many of your existing light vehicle vendors also offer HD parts solutions. Your WD or DC might not stock a full line of heavy-duty parts, but many basics like filtration, lighting, belts, rotating electrical and batteries are often only a daily order away. For slower-moving HD-specific parts, special ordering from existing vendors is often a realistic possibility, assuming your customer can absorb the downtime.
Most heavy-duty customers are commercial operators, and time spent waiting on parts is money lost for their businesses and yours. Quick turnaround times for these orders are an everyday expectation in the HD world, so last-moment requests and expedited shipping charges are common. For a parts specialist who enjoys a challenge, the occasional HD parts lookup represents a chance to flex their interchange and cross-reference muscles, and maybe even learn new ways of problem-solving that can be applied to their “regular” daily tasks!
