buy second hand engines Holden Special Vehicles VF HSV LSA CONVERSION KIT COMPLETE
- 317 views
- 265 views
Cash For Caravans Brisbane
By CarPartAU,
- buy second hand engines
- buy/sell car parts online
- (and 2 more)
- 7,663 views
Car Part | 2006 CHRYSLER PT CRUISE CARPET
By CarPartAU,
- genuine brand auto parts
- buy a car engine
- (and 1 more)
- 1,263 views
2013 / 2019 BN BM MAZDA 3 2.0 PETROL ENGINE / MOTOR
By CarPartAU,
- nitro in cars
- top 10 auto parts stores
- (and 2 more)
- 1,334 views
Dayco, a supplier of engine products and drive systems for the automotive, industrial and aftermarket industries, is expanding its timing chain kit line with 41 part numbers to cover another 49 million vehicles in operation (VIO). Additionally, the company is introducing the next generation of its AutoPartIQ inventory assessment tool—with new features for a more productive customer experience.
New Parts Bring Timing Chain Kit Coverage to 120+ Million
Dayco’s aftermarket team launched the line in 2022 due to the car parc shift from timing belts to timing chains at the OE level. The
link hidden, please login to view, which feature OE-quality components, cover high-volume light-duty engine applications. They include all the necessary components for a thorough and complete repair, building on Dayco’s mission of recommending system replacement as a best practice. Dayco says the kits include: Timing and secondary chains that prevent stretch for the life of the kit – and address the no. 1 replacement issue; Precision-machined cam and crank sprockets for quiet, noise-free performance; Direct fit OE-quality, high-grade plastic guides, as well as VVT solenoids and cam phasers when the application calls for it; and Packaging that features a QR code that links directly to detailed installation instructions. Dayco backs its entire timing chain kit line with an industry-leading two year or 60,000 mile (96,000 kilometer) link hidden, please login to view, whichever occurs first, giving technicians confidence in what they’re installing. Three of the new part numbers are already available, and the remaining 38 are scheduled for Q1 or Q2 2025.
“We entered the timing chain kit market to meet the needs of our customers. The line continues to grow with sales increasing year over year and we are supporting our high-quality product line with important investments in warranty and training material,” said Tom Tecklenburg, Vice President, Aftermarket, Dayco North America. “We encourage our customers as well as shop owners to reach out to our tech team to schedule virtual training and to learn more about this line if they aren’t already stocking it.”
