U-POL Raptor Product System, Pt. 3: Texture Replacement
By Mighty Auto Parts
Valvoline announced that its Restore & Protect motor oil has been named 2025
link hidden, please login to view winner in the car care category. The company said the product was selected for this honor through a national study of 40,000 American shoppers, as surveyed by Kantar, a consumer research firm. As the largest consumer-voted awards program recognizing product innovation, the Product of the Year award is recognition of the benefits Restore & Protect offers to consumers, link hidden, please login to view said. Launched in January 2024, Valvoline said
link hidden, please login to view is the first motor oil designed to effectively restore a car’s engine to perform like new. The company said its product continues to challenge traditional views of the role motor oil plays in engine care and is setting a new benchmark for performance in the industry. “As we constantly strive to deliver exceptional products to our customers, we are honored to be chosen by consumers as a 2025 Product of the Year award winner,” said Greg Barntsen, Valvoline Global operations general manager – Americas. “Restore & Protect is not only on the forefront of value-added innovation in our industry, it’s a reflection of Valvoline Global’s commitment to inventing the way forward with innovative solutions to global automotive challenges.”
link hidden, please login to view announced it achieved another milestone in 2024 with the launch of 107 high-VIO part numbers, covering more than 30,211,120 applications through model year 2025. The launch of 107 new vehicle mounts includes: 57 part numbers for domestic applications; 22 for European applications; 21 for Japanese applications and 7 for Korean applications.
For more information, contact your local sales representative, or call the
link hidden, please login to view customer service department at 888-444-4616. Visit
link hidden, please login to view for more information. The post
