    • By Auto News
      link hidden, please login to viewWith a majority of vehicle owners living in areas of the country that have stay-at-home orders, many vehicles may be sitting idle for days or weeks at a time. The non-profit Car Care Council recommends starting your car at least once a week and keeping up with routine auto care to help prevent potential maintenance issues. “Just as it is recommended that people stay active during this time of social distancing, your car should get some activity as well,” said Rich White, executive director, Car Care Council. “If your vehicle sits idle for too long, the battery could die, the tires can develop flat spots and the engine oil may start to deteriorate. Just a short solo drive once a week and a little car care will keep your car running efficiently and safely.”
      link hidden, please login to view to order the Car Care Council’s free 80-page Car Care Guide. The post
      Do you know how to correctly install a new vehicle battery?
      Since the beginning of the year, Schaeffler said it has provided its customers with a CO₂e emissions calculator. The company said all that is required is the input of load and speed data in the online product catalog “Schaeffler medias.”
      Schaeffler explained that to achieve its climate targets, companies require transparency regarding the CO₂ emissions created by supplier products. Schaeffler now provides this information for the majority of its rolling bearing product portfolio.
      Based on these emission values, customers can make data-based investment decisions, which are in line with their sustainability targets.
      link hidden, please login to view said it displays the emissions in so-called carbon dioxide equivalents, abbreviated as CO₂e, as a metric measure used to compare the emissions of various greenhouse gases based on their global-warming potential (GWP). Since the beginning of 2025, the calculator in the digital product catalog “Schaeffler medias” has not just offered the option of calculating the production-related CO₂e emissions at individual bearing level. It also shows the emissions caused by friction losses in the bearing during the utilization phase.
      “Our customers can now find out quickly and simply how many CO₂e emissions are produced by the operation of a rolling bearing in their application – and therefore how the selection of a bearing with optimized friction behavior has an impact on the operating costs in quantitative terms,” explained André Schade, sustainability coordinator for product development in R&D at Schaeffler Bearings & Industrial Solutions.
      Relevance for all industrial sectors
      Because this information can be found directly in the product catalog, customers who are registered with “Schaeffler medias” can select their desired products as usual. They also have the option of defining the planned application based on several load cases. To receive informative values on CO₂e emissions during the use phase, all that is required is the input of load and speed data for the application. This allows for instance a comparison between friction-optimized and standard bearings,
      link hidden, please login to view said. High level of detail in “medias EasyCalc”
      Schaeffler added that customers can delve deeper into this topic on the platform “
      link hidden, please login to view”: The influences of lubrication, operating temperature and oil flow during application can be included in the calculation. The platform also features direct links to Schaeffler’s solutions in the fields of mounting (assembly, fitting) and lubrication, as well as a link to a tool, which shows how the production in many sectors can be made more sustainable using Schaeffler products, the company said.
