With a majority of vehicle owners living in areas of the country that have stay-at-home orders, many vehicles may be sitting idle for days or weeks at a time. The non-profit Car Care Council recommends starting your car at least once a week and keeping up with routine auto care to help prevent potential maintenance issues.
“Just as it is recommended that people stay active during this time of social distancing, your car should get some activity as well,” said Rich White, executive director, Car Care Council. “If your vehicle sits idle for too long, the battery could die, the tires can develop flat spots and the engine oil may start to deteriorate. Just a short solo drive once a week and a little car care will keep your car running efficiently and safely.”
to order the Car Care Council’s free 80-page Car Care Guide.
  • 4 weeks later...
  • 4 years later...
      Wiper blades keep your windshield clear, but since they’re made of rubber, they wear out with time and need to be swapped out regularly.  How long they last really depends on how often you use them, where you drive, and whether you take care of them. Watch for these signs that indicate it's time for new wipers:
      Streaking or Noise
      Visible Damage
      Age Considerations
    • By Teddy
    • By Jacky Xine
      How would you love to modify your pickup? I will show mine first.
      I have changed the grille, headlight, and the side steps. How about it now?
