I think this relates to many GM newer engines, but I ran into this recently on a late model Chevy Equinox that seemed to have an oil consumption issue. The car was burning 2 quarts every 2-3k miles. now the dealer states that it's normal to burn 1/2 a quart every 1k miles, so this was excessive. I had the oil changed and they used Dexos spec oil and the consumption got significantly less. They say to use a blend or full synthetic. Prior to this I had Valvoline perform the routine maintenance with standard oil not really thinking about it until I noticed an engine rattle after being 2 quarts low, especially on turns. Once I topped it off, it went away. Nevertheless,  I felt it was consuming and took it to the dealer. So now, Dexos only approved oil and i never thought about it but it says Dexos right on the oil cap. Anyone else run into this?
      Improved Chevy S10 and Blazer console lid | Dorman OE FIX 925-001
      What you can learn about a DTC using an inexpensive scan tool
    • By chevyguy
      I've got a 2014 Chevy Equinox with new pluigs, coils, fuel injectors, recent top-engine carbon clean, new AC Delco O2 sensors, and relitively new CAT. Getting a P219A-00 for Fuel trim cyliner balance. Any ideas where to start diagnosing? I saw this online as possible causes:
      Leaking or contaminated fuel injectors Low fuel pressure or running out of fuel Leaking evaporative emission (EVAP) canister purge valve Exhaust or intake air system leaks Exhaust gas recirculation (EGR) system Positive crankcase ventilation (PCV) system is leaking or the valve is stuck open Ignition system Incorrectly seated engine oil dipstick, tube or oil fill cap Just curious if anyone has had this issue with a GMC of Chevy and succesfully diagnosed.
      Do you know the right way to use rasps and files?
      Selling the Upgrade
      Bottom Line for Counter Pros
